Multifunction DAQ
NI-DAQ 9191 won't communicate wireless
I am trying to get my DAQ9191 to communicate wirelessly with my network. I used max to set it up and my wired network will communicate with it. max sees my wireless network and says that it is connected. but when i check there is no ip address for wireless. i have went to my router setup and checked what it is seeing, it sees the wired connection but no wireless one. i am thinking that the 9191 is receving since the wifi lights transmit but is not transmitting any data to my wireless modem. I have reset the 9191 and get the same results
(4,167 Views)
Hi there,
The following documentation may prove useful:
'What link does a cDAQ-9191 prefer when both wireless and wired are connected?'
http://digital.ni.com/public.nsf/allkb/B7119F2E45B8509186257983007CE5A2?OpenDocument
There could be an issue with the router you are working with. You may try to set up a direct wireless connection between the cDAQ-9191 and the host PC:
'How Do I Set Up an Ad Hoc Network on My NI cDAQ-9191?'
http://digital.ni.com/public.nsf/allkb/BC8A12AD883D6825862579E500766E15
Hope this helps!
~ Q ~
(4,091 Views)
