Multifunction DAQ
NI PCI-4472B
Hi there:
Does any one suggest an industrial Laptop or UMPC for this NI card : NI PCI-4472B.
I Want to have it installed in a portable solution, so if someone can help choose the right PC, it would be really nice.
Thank's in advance.
ELBOB
(3,305 Views)
Hi ELBOB,
I don't know of any laptops or ultra-mobile PCs that have PCI slots.  There are a few companies that have portable industrial PCs with PCI slot's, however they are significantly larger than a standard laptop.
A quick google search for "industrial portable pci" or "industrial portable computer" yields:
http://www.bsicomputer.com/new/portable/portable_workstation_index.htm#1
http://www.stealthcomputer.com/portables.htm
http://www.theportablepc.com/
NI does not recommend a specific manufacturer, though the PCI-4472B should work with any computer that meets the LabVIEW system requirements, has a PCI slot and a supported operating system.
These portable  PCs are much larger than a laptop.  An alternative would be to use the USB-4432, which has the same sampling frequency, a few less channels, but connects easily through USB.
There are also a few companies who create USB to PCI bridges, however these are not supported by National Instruments and may not be compatible with our cards.
Eric S.
AE Specialist | Global Support
(3,289 Views)
