Multifunction DAQ
NI USB 6525
Hallo ,
I am very new to this NI USB 6525 environment. I have installed NI MAX for USB-6525. I would like to ask you all the can somebody please recommend me how to perform test on USB-6525 initially just to check I/O's ???
Also my other question was that, is it necessary to have Labview, Labwindows installed for this NI USB-6525 ??
Thank you in advance
Message 1 of 9
(5,110 Views)
Hallo ,
Message 2 of 9
(5,108 Views)
In MAX, if you select your DAQ there will be a button towards the top for Test Panel.  That will open a dialog allowing you to check out all of the IO.
LabVIEW and LabWindows\CVI are programming environments.  They are not necessary for using the DAQ.
GCentral
Message 3 of 9
(5,086 Views)
Thanks yes there is the Button. But can you tell me how will I cross it ??
I am attaching the screen short of my DAQ.
Message 4 of 9
(5,079 Views)
I have no clue what you mean by this.  Maybe you just need to press the Start button to run the task you defined?
GCentral
Message 5 of 9
(5,075 Views)
Yeah. It worked. Thanks
Message 6 of 9
(5,071 Views)
Hallo,
I want to build such kind of circuit. I will be giving 10V input.
Can you suggest me how to run the DAQ-6525 ??
I have shown the schematic below.
Message 7 of 9
(5,037 Views)
Have a look at the manual of the USB-6225 and use one of the Digital-Outs.
Regards, Jens
Kudos are welcome...
Message 8 of 9
(5,029 Views)
Hallo
I went through your instructions. And I perform in such a way as shown in figure below.
Now I am getting output. Is it right ??
Another think I want to ask you is that, is it possible to provide input to one of digital input pin and get the signal on any other digital output ??? If yes than can you please describe what steps to do ??
Thank you in advance.
Please find the image below.
Message 9 of 9
(5,026 Views)
