Multifunction DAQ
NI cDAQ 9133 with Windows, not enough C: drive space
We have developed an engine test cell controller which we've been using for the last several months with an NI cDAQ 9133. The DAQ only has about 15 GB of C: drive space. It seems Windows takes about 10 of that and Labview takes everything else. As we've slowly approached 100% capacity over the last few months, the system has basically come to a standstill. I'm not sure what the long term solution would be but right now I'd like to attempt reinstalling everything and leaving out some of the Labview modules that I don't need to free up a little more space. My current issue is that I can't even get MAX to work correctly so that I can export all of my sensor calibration data. I'm getting NI-DAQmx 16.1 error 229771.
Any thoughts on general approach or the specific error I'm encountering?
Thanks, Josh
(2,098 Views)
Hey Josh! You might try taking a look at this article for some steps to troubleshoot your 229771 error. It has a few different solutions that could resolve that error and allow you to export your calibration data.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7a7SAC
(2,071 Views)
