Multifunction DAQ
NI9232 Suitable for PCB-356A02 Acceleration Sensor
i need to measure acceleration(s) for a "Head-Impact" Test. My boss already ordered a 3-Axis (but only 2-Axis needed) Acceleration Sensor, which can be found here: http://www.synotech.de/produkte_skript/downloads/specs/356A02_specs.pdf .
A Testengineer in my company (im a "working student" there) recommended the NI9232 DAQ for data aquisition, but im not sure if its the best fit. the +/- 30V range is already to much, so ill have to amplify the sensor signal. But is it even possible to connect the sensor (not directly  the sensor, but this supply unit: http://www.synotech.de/produkte_skript/downloads/manuals/482C05_manual.pdf ) with a bnc connector? The article-number he gave to me was "782000-01", but that version doesnt have bnc inputs as far as ive seen.
Im sorry if this post is a bit confusing as i have little time.
Alexander Malter
(3,533 Views)
Hi there,
I would strongly suggest you to contact your local National Instruments sales person  to discuss with him your project.
Certified LabVIEW Architect (CLA)
(3,519 Views)
Accepted by topic author Ridcully
With a 6kHz bandwidth nealy any IEPE devive with  20kHz samplerate and two channels will do the job.
The 30V range isn't the problem, the resolution is still high enough, with about 2% to 5% uncertaincy of the sensor 10bit (8bit) residual resolution will do the job.  with a 60V input range and 10V output range (ok, say you sensor application only uses less than 4V... you loose about 4 bit of your cards ENOBs)
The challanging part is the connector 🙂
The datasheet tell it's a 1/4-28 4pin connector. and usually the NI IEPE devices have a BNC...   so you need an adaptor (ask synotech, or your boss already ordered one ;))
Greetings from Germany
Henrik
LV since v3.1
(3,506 Views)
Thanks for your help, the cable is not the problem, because we already ordered the appropiate one.
(3,444 Views)
