Multifunction DAQ
Need help in synchronizing hardware output digital pulse generated on USB 6009 with tht of system time(nimute, hour or seconds)?
I am using generate contineus pulse vi, to generate pulse on port of NI 6009 DAQ, I am getting system time using  get time/ date function. But i want to output a pulse only at specific time like 5.30.11, or say on tick of every second. i. e 1 pulse per second but synchronized to system time. How can i do that? pls help.
(3,003 Views)
6009 is entirely software-timed, so your'e going to get a couple of mS jitter between pulses due to windows processes, software priorities, and bus latency.
If you want a good 1-pulse-per-second you're going to need a timebase; something like the PXI-6682 or Symmetricomm XLi.
(2,999 Views)
thanks for reply.
but i want to use system time only...no matter if i get ms delay if i can determine tht delay also.
i just wanted to know 1. how can i generate pulse at every changing second? 2. how to determine the delay ?
pls help
(2,994 Views)
