Multifunction DAQ
Noise appearing in signal after filtering
I am filtering a signal from a pressure transducer and after it's filtered a small spike of noise shows up at the beginning of the sample that isn't in the original data.  I talked to friend here who has seen a similar thing.  Does anyone have any experience with this?  I just want to clean it up.
I have attached to screen shots examples.  The graphs on top and bottom are zoomed equally.
(3,045 Views)
When you apply the filter, if the first point is non-zero, you see this effect.  What I usually do is find the value of the first point, subtract that value from the whole waveform, apply the filter, and then add the value back to the waveform.
Randall Pursley
(3,024 Views)
Thanks for the tip.  That seems like a reasonable work around.
I tried to do that but in changing the first value converts the dynamic data to an array.  When I change it back the filter doesn't work.  Any ideas there?
(2,995 Views)
I don't work with the Dynamic Data type much so I didn't foresee your problem.  If you convert the DDT to a waveform and then extract the data, you can then do the subtraction and then convert it back to a DDT.  It's inconvenient, but I don't really see how to do it within the DDT.
Message Edited by rpursley8 on 05-17-2010 11:39 AM
Randall Pursley
(2,967 Views)
