11-16-2010 03:09 PM
I find that after restarting my computer, my PCI-4065 DMM is not recognized in MAX (where I gave it the device name "DMM"). If I look at the devices available in MAX, the device I named "DMM" is not there, and it has found a "new" device named "Dev1". If I delete the old "DMM" and rename the "Dev1" to "DMM" my program works properly. Is there a way I can keep this from happening?
Mark
11-17-2010 11:03 AM
Hi Mark-
This sounds like an issue with the driver. Do you have any other devices in your computer? Do they behave the same? Which version of NI-DMM do you have? If your OS supports it, it may be good to try upgrading your driver to NI-DMM 3.0.2.
I hope this helps. Have a great day!
