Multifunction DAQ
PCIe-6232 Phase lock ref Clock to ext 10MHz
I have the PCIe 6323 Card and an ultra stable 10MHz reference coming from a Maser. I converted the signal to sqarewave signal with an amplitude of 3V. I want to Phase lock the NI cards reference clock to the 10MHz external one. I connected the cable to a PFI connector. how do I program Labview so it phaselocks the Clock? When I just  write it in the DAQmx-Timing (see pic in the attachments) the program does not work any more.
Thanks for helping.
Sebastian
(3,827 Views)
Hi qport,
Why do you don’t work with the DAQmx Timing VI?
Here you have the possibility to select a sample Clock Source.
http://digital.ni.com/public.nsf/allkb/3E3D74E26B8A5B83862575CA0053E4B5
Take also a look at the example "HW-Timed Single Point Input.vi".
Open the NI Example Finder in LabVIEW at "Help --> Find Examples..."
Then Browse "Hardware Input and Output --> DAQmx -->Analog Input"
(3,798 Views)
Hi qport!
In order to phase lock your PCI DAQ card, you'll need to use a RTSI cable, which I see you are using in your VI.
Edit: I just noticed you're using a RTSI cable. You can find the example in LabVIEW under DAQmx -> Syncronization, but I believe you need to set the RefClk.Src in your Timing Property Node to point towards the RTSI input. The Reference Clock is what your Sample Clock is divided down from, I believe. When you set the RefClk.Src, it will PLL the clocks, and then the sample clock will be derived off the PLL clock.
However, if you are using a PXI chassis, you can phase lock clocks rather simply over the backplane.
(3,784 Views)
Thank you for your replies,
the phase lock works now. As you proposed I set the channel with the external reference as RefClk.Src. When I measure the 20MHz Timebase freq against the 10MHz input I see that they are phase stable now.
But:
now I  run into a new problem when i try to output digital (DIO0-31) and analog (AO0-4) signals triggered by a sample clock created with a counter(see pic attached). It gives me the error 89137 with the describtion :
<B>Eigenschaft: </B>RefTakt.Quelle
<B>Quellgerät: </B>Dev1
<B>Quellenanschluss: </B>None
<B>Benötigte Ressourcen belegt von</B>
<B>Task-Name: </B>_unnamedTask<0>
<B>Quellenanschluss: </B>RTSI7
<B>Zielgerät: </B>Dev1
<B>Zielanschluss: </B>RefClockInternal
(sorry that it is in german)
Thank you for helping
(3,766 Views)
