Multifunction DAQ
PFI-DAQcard 6023E
Hi NI community,
I am using DAQ card-6023E to generate some digital signals and clock. I am trying to use PFI as clock for generating the data i.e. directly connecting the output of clock to input of digital data at hardware, but i always get error message at the output of sample clock(both programs and error message attached).
I have tried to fix it but couldn't. I would appreciate if someone can help.
Best
(2,670 Views)
Hi Qureshi,
Unfortunately, the 6023E only allows for software-timed Digital updates.  To output digital data on the 6023E, you will have to write a single sample each time inside a loop in software.  If you need clocked digital lines you will need to change hardware to a board that supports clocked digital I/O.
Best Regards,
John Passiak
(2,654 Views)
