07-07-2017 08:42 AM
Hi to all,
I have created a vi using DAQ 6211 card to plot values in XY graph and waveform chart. However i need to add a DAQmx timing palette to have a sampling rate actually i need to display 1 to 100 samples per second but i can't display at same interval for all the numbers i need some doubts to be cleared here and also i need to add a time function in seconds in xy graph in addition to the channel 1 and channel 2, i've attached my vi to this, you can tell whatever i done wrong here.
Thanks in advance,
Dinesh
07-12-2017 11:12 AM
Sorry, currently stuck with LV2012.
you need two FIFO buffer (or ring buffer)
size of the buffer SR*(time to display in XY)
you read a block of data every 100ms to 1s , feed it into the buffers , read the buffers and display it in a XY graph.
