08-11-2014 01:13 PM
Hi All,
I have a project I'm working on which requires reading values from a circuit board.
Need to do these things:
1). Read five analog values from test points on a circuit board with USB-6000 DAQ Unit.
2). Read tachometer from fan with a counter from USB-6000 DAQ Unit.
3). Read a temperature value from USB-TC01 Thermocouple Unit.
We can't use LabVIEW because we would need to recode our entire python low-level driver to interface with the software. Instead, I want to utilize PyDAQmx module to interface with the NIDAQmx driver.
However, I'm not sure how to use the functions in PyDAQmx to utilize reading values from the boards and units. Any help would be appreciated, thanks!
Best,
Jacob
08-11-2014 01:48 PM
08-11-2014 01:51 PM - edited 08-11-2014 01:53 PM
I've looked into that website, and into the GitHub source code - there doesn't seem to be much information/documentation about compatibility with the USB-TC01 Thermocouple Device. I'm looking to interface all this hardware together, but there isn't a "how-to" guide.
Edited for clarity
08-11-2014 01:54 PM
Edited for clarity
That's what happens when you use open source software. You get what you pay for.
08-11-2014 01:58 PM
My assumption was that if the USB-TC01 Thermocouple Device uses the NIDAQmx 9.9 drivers, it should have compatibility within the PyDAQmx module since its a full interface to the NIDAQmx drivers.
08-11-2014 02:14 PM
Go with your assumption. No one is stopping you.
08-11-2014 02:19 PM
08-11-2014 02:21 PM - edited 08-11-2014 02:21 PM
Either help contribute, or don't reply. I'm not looking for passive-agressive answers - this goes to nyc
08-11-2014 02:27 PM - edited 08-11-2014 02:29 PM
Dennis,
I essentially want to use a method that would read the value of the thermocouple, and print the value when I type "T"
For instance:
while True:
print "Commands"
print "T --> Read current Thermocouple Temperature"
print "FON --> Fan On"
x = raw_input("Enter Command:")
if x == "FON":
fan1.write_fan_duty_cycle(100)
08-11-2014 03:13 PM
