Multifunction DAQ
Quadrature encoder 6602 bad values
The behavior originally reported on this thread was changed in DAQmx 9.0 for position measurement tasks (both angular and linear). When reading scaled (DBL) data from a position task, the driver will typecast the raw count value to an I32 so it may represent negative numbers appropriately before applying the scale.  A side-effect of this is that the scaled result will "roll-over" when the count hits 231, which will instead be interpreted as -231.
Edge count tasks currently still roll-over to the U32 value represented by the count register.  For the discussion on the edge count behavior, see here.
Best Regards,
John Passiak
Message 11 of 11
(588 Views)
