Multifunction DAQ
Route 6652 DDS clock to PFI lines
I am using C/C++ to program PXI-6652 module. I need help routing DDS clock output to one of the PFI outputs.  Can you please share an example code?
Thanks.
(2,629 Views)
You can take a look at the CVI examples located at:
C:\VXIPNP to C:\Program Files\IVI Foundation\VISA\NISync\Getting Started
for examples on routing clocks and triggers in C.  You should be able to convert these examples to C++.  You can refer to page 2-2 for more information on that.
You can access both the examples and documentation by going to Start»Programs»National Instruments»NI-Sync .
Let me know if you need more help on this.
O. Proulx
www.ni.com/support
(2,611 Views)
