07-20-2013 07:22 PM
Hi all, I'm new to LabView and these forums I hope to learn and contribute much in the near future.
I created a simple VI that takes Desired Temperature and Current Temperature as inputs, compares them, and then applies a voltage based on the comparison ( CurTemp < Desired --> voltage out) but I'm having trouble understanding why when Current Temp = Desired Temp the DAQ continues to generate a voltage. This occurs even after the VI is stopped completely. VI is attached and thanks for any suggestions!
Sleepar
Tech Info:
NI 6009 DAQ
Win 7 x64
LabView 2012 Student Edition
Solved! Go to Solution.
07-20-2013 07:33 PM
An analog output will hold the last value written until he device is reset. You need to make sure to write out a 0V when you don't want an output and when closing down your program.
07-21-2013 12:48 PM
Crossrulz,
Thanks a ton my friend, I expected the solution to be so simple it makes you want to kick yourself for not having thought of it; and of course it was!
Sleepar
