Multifunction DAQ
USB-6009 with nidaqmx & PyDAQmx Analog output error code -200077
Hello everyone
I want to use pydaqmx or nidaqmx to control USB-6009 DAQ to output some square wave. I follow the installation instructions(nidaqmx in anaconda 3 and PyDAQmx in pycharm), and python version 2.7.12 and 3.5 are used.
If I try nidaqmx input examples, no error happens. But if I try nidaqmx output example, error happens.\ The same problem happens on PyDAQmx&pycharm environment. I believe it's not the problem about nidaqmx or PyDAQmx. And USB-6009 can output voltage between from 0 to 5 volts from test panel in NI MAX. I change the input value in the program from integral to float between 0 to 5 volts. But the error always display that my requested value is 10.0 V. How to solve the problem?
DAQError: Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: DAQmx_AO_Max
Requested Value:  10.0
Maximum Value:  5.0
Minimum Value:  0.0
Channel Name: Dev1/ao0
Task Name: _unnamedTask<1>
Status Code: -200077
 in function DAQmxStartTask
Fanglin
Message 1 of 14
(8,409 Views)
Hello everyone
If I try nidaqmx input examples, no error happens. But if I try nidaqmx output example, error happens.\ The same problem happens on PyDAQmx&pycharm environment. I believe it's not the problem about nidaqmx or PyDAQmx. And USB-6009 can output voltage between from 0 to 5 volts from test panel in NI MAX. How to solve the problem?
Fanglin
Maximum Value:  5.0
Minimum Value:  0.0
Message 2 of 14
(8,409 Views)
Can you attach your code?
Ian
LabVIEW since 2012
Message 3 of 14
(8,372 Views)
Hello skycrazy00:
As far as I understand the issue you want to develop an input and an output task, but when you run the program you receive the error message.
According to this error message, you are requesting a higher value than the possible limit to the hardware. Also, you are aware of the physical limits of the maximum and minimum amplitude.
Did you modify the example you provide as a reference?
Can you share the code you are currently working with?
Message 4 of 14
(8,354 Views)
Sure! I just use the example in nidaqmx doc to test the device and lib.
import nidaqmx
with nidaqmx.Task() as task:
    task.ao_channels.add_ao_voltage_chan('Dev1/ao0')
    print('1 Channel 1 Sample Write: ')
    print(task.write(1.0))
    task.stop()
nidaqmx example.
from PyDAQmx import Task
import numpy as np
value = 1.3
task = Task()
task.CreateAOVoltageChan("/Dev1/ao0","",-10.0,10.0,PyDAQmx.DAQmx_Val_Volts,None)
task.StartTask()
task.WriteAnalogScalarF64(1,10.0,value,None)
task.StopTask()
 Thanks for reply.
PyDAQmx example.
Message 5 of 14
(8,349 Views)
Sure! The same thing as in nidaqmx doc.
import nidaqmx
    task.stop()
nidaqmx example
import numpy as np
value = 1.3
task = Task()
task.StartTask()
task.StopTask()
PyDAQmx example.
Two lib get the same error. I think it's not the problem of nidaqmx python lib and pyDAQmx lib.
Thanks for the reply!
Message 6 of 14
(8,345 Views)
Hi! I just want to generate a square function with accurate frequency. I tried digital output just now and it works, but the time delay is controlled by python in computer. I check the doc about the USB-6009 and I find there is a counter in the chip. Can I use the counter to set accurate time delay with square wave output by digital output?
Fanglin
Message 7 of 14
(8,337 Views)
Hi
JKarma also mentioned this, but that error means that you are requesting something from the hardware that is not a valid option. Please check this:
http://digital.ni.com/public.nsf/allkb/440EB533229211CD8625711C007E61B3
Message 8 of 14
(8,327 Views)
Thanks for the reply! I know the limitation voltage output of USB-6009 is between 0 to 5 volts, and actually all the voltages I write in the program is between 0-5 V. And that problem happens all the time.
So I give up using USB-6009! I find a USB-6351 as the generator.
There are function generator inside USB-6351 and I can output impulse sequences through test panel in NI Panel. But when I want to program it in Python, there are problem happens.
DaqError: Specified operation did not complete, because the specified timeout expired.
Task Name: _unnamedTask<34>
Status Code: -200474
And my code below
import nidaqmx
from nidaqmx.types import CtrTime
    task.co_channels.add_co_pulse_chan_time("Dev2/ctr0")
    sample = CtrTime(high_time = 0.001, low_time = 0.001)
    task.write(sample)
Thanks!
Message 9 of 14
(8,300 Views)
I am using NI-USB 6008 and have exact the same problem. So for the begining I just want a simple program where I can give as input 1 and analog output would give out 1V (or 2V or 3V). I am new in python programming so I used an general online code:
import nidaqmx
task.write(1.0)
task.stop()
So with this I want that on my analog output is 1V. But insted I get an error massege as number of peopel before me.
Error massege is:
nidaqmx.errors.DaqError: Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Maximum Value:  5.0
Minimum Value:  0.0
Task Name: _unnamedTask<0>
Process finished with exit code 1
This problem was discussed already on forums before, but I could not find a solution. Can someone explain what is wrong with the code?
NNovak
Message 10 of 14
(6,981 Views)
