Multifunction DAQ
USB 6225 new version
I have recently bought a USB 6225. The new version can be connected with the SH-68-68-EP and SH-68-68-S, top image. The old version that I have in the office have some pins that you can easily connect your input voltage, lower image.
Can anyone help with this? Do  we need to buy something extra?
(992 Views)
The top image is the mass termination variant whereas the bottom one is screw terminal variant. See 62xx Models : DAQ Multifunction I/O Cable and Accessory Compatibility for the choices of cables and terminal blocks.
(978 Views)
Thanks a lot for answer.
A converter like this work with this mass terminals to get the pins out?
https://nl.rs-online.com/web/p/scsi-connectors/7390779?cm_mmc=NL-PLA-DS3A-_-google-_-PLA_NL_NL_Conne...
(925 Views)
I am not sure if that specific component will work. NI provides a list of recommended part numbers. Based on 68-Pin VHDCI Cables : DAQ Multifunction I/O Cable Guide, SHC68-68 cable has 68-pin 0.8 mm VHDCI Connector Male (Plug) and 68-pin 0.050 in SCSI D-Type Connector Female (Receptacle). The recommended orderable part numbers are provided in those links.
(915 Views)
