Multifunction DAQ
USB 9213 recognized but keeps restarting
I have a USB ni touch panel 2206 running windows XP embedded. I have installed DaqMX 9.3.5 and Measurement & Control 5.0.
When I plug in the Hi-Speed USB Carrier (Ni USB-9126) it shows up under Device Manager>Data Acquisition Devices> USB-9126 No Cartridge
When I plug in the 9213 thermocouple module, the system recognizes the two of them for 2 seconds and then they shut off. It goes through and endless loop of found new hardware, and then they shut off.
I have plugged in the 9213 thermocouple module with my Ethernet carrier (NI CDAQ-9181) and it works fine. I am able to get perfect readings.
Has anyone witnessed these sort of hardware issues with the 9213 or any other module?
Thank you
(2,590 Views)
Hello Laptopolus,
I would recommend you to uninstall DAQmx 9.3.5 and install DAQmx 9.5.5 or DAQmx 9.6.
Have a good day!
(2,585 Views)
