05-18-2009 02:09 PM
05-18-2009 02:16 PM
05-18-2009 03:26 PM
05-18-2009 03:44 PM
Everything you read said it requires LabvIEW 7 or higher correct? Everything you read is correct.
If you did a thorough search, I think you would have seen that the only possible way out is to use the call library function node to access the DAQmx dll. This would not be trivial but it would be about what you have do in a text based language - specify the function, define the parameters, etc.
05-20-2009 09:41 PM
If you're in a pinch and only need to acquire data, you can use the Free LabVIEW SignalExpress LE software.
You can also try the Evaluation version of LabVIEW 8.6 for free for 30 days, which may get you through your project...
