08-20-2009 05:25 AM
I've set up my DAQ assistant to record voltage inputs. I am using an NI-9162 to record voltage values and then outputing the data to a .txt file. I want to set it up to record two samples a second and to run for 8000 samples but it doesn't seem to want to do this. When I run the program the following error comes up:
Measurements: Some or all of the samples requested have not yet been acquired.
To wait for the samples to become available use a longer read timeout or read later in your program. To make the samples available sooner, increase the sample rate. If your task uses a start trigger, make sure that your start trigger is configured correctly. It is also possible that you configured the task for external timing, and no clock was supplied. If this is the case, supply an external clock.
Property: RelativeTo
Corresponding Value: Current Read Position
Property: Offset
Corresponding Value: 0
Task Name: _unnamedTask<2C>
I have it set to read 8k samples and 2 hz
Any advice would be appreciated
08-20-2009 10:07 AM
