Multifunction DAQ
What device drivers are compatible with Linux C platform?
I'm trying to identify a device or devices to give me 16 analogue outputs, 1 digital output and 3 digital inputs. Preferably this would use an Ethernet interface but USB would be acceptable. The software controlling the device(s) would be written in C running on Linux.
I've done lots of searching on the NI website and it's starting to look like there are just a handful of USB devices which are compatible with Linux if using the NI-DAQmx Base 3.6 drivers. Is that correct? I also read a page on the NI-DAQmx Base drivers which states 'Developers creating applications for Windows and Linux-based systems should consider using the latest in full-featured NI-DAQmx.' but I can't find any version of (full) NI-DAQmx that list Linux in their supported OS list.
I would appreciate any clarification anyone can offer.
Thanks.
CAS
(5,036 Views)
I have managed to find some more information so I can answer some of my own questions here.
It would appear that there are some reasonably recent versions of full NI-DAQmx that are compatible with Linux. I found these by Selecting 'NI Drivers' from the 'Support & Services' option on the home page and selecting 'NI-DAQmx' from the 'Hardware Driver' list. There is then an option on the left-hand side to filter by OS. At the time of writing, the most recent version for RedHat and SUSE is 8.0.2.
The 'Readme' file on the download page includes a list of compatible devices. This includes some PCI, PCIe, PXI and SCXI devices so I guess I'm out of luck for the CompactDAQ Ethernet or USB devices I was after.
Another useful resource that I was not previously aware of is the Linux Users Community Group which has some useful information.
I hope this information is useful to others. I would still appreciate any suggestions others might have regarding my original requirement.
CAS
(5,012 Views)
NI provides Linux support for a subset of the USB DAQ devices via NI-DAQmx Base [1], where the "Base" means subset. The USB devices supported there are: USB-621x, USB-6008/9, USB-6501, and the NI cDAQ modules 9211, 9214, 9233, and 9234 in the USB-9162 single-slot sleeve.
[1] NI-DAQmx Base 14.0 for Linux
http://www.ni.com/download/ni-daqmx-base-14.0/5054/en/
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(4,984 Views)
Not Linux in general, just a few handpicked kernel images and userlands from a few handpicked distros. Anything else is just Russian Roulette.
(kernel drivers have to built w/ or for the actual target kernel)
Seems so, as long as nobody is having far too much spare time and reverse engineers the whole thing. NI keeps the necessary specs for writing drivers ultra-secret. And their proprietary kernel drivers cant ever work reliably. (the kernel never supported that).
For USB side it will be even funnier: the USB subsystem enforces the GPL, therefore proprietary usb drivers are not tolerated anymore. Releasing the source as GPL would mean publishing the device details.
http://forums.ni.com/t5/Multifunction-DAQ/Linux-NIDAQmx-install-problem/m-p/3225670/highlight/false#...
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(3,507 Views)
