03-08-2018 04:06 AM
Hi at all,
i m struggling with the wiring of my two sensors to a 9207 Module which is placed on a cDAQ 9136 Device
Setup:
cDAQ 9136
Module Ni 9207
Biotech Flow Sensor:
Pin 1: +5-24 VDC
Pin2: Ground
Pin4: S
Gems Pressure Transducer ( code G, Current mode )
Pin1: +V
Pin2: Return ( 0V )
Pun 3/4: Not connected
Datasheets:
attached below
Issue:
The wiring of the sensors at itself seem pretty clear. I Just don't know how to connect it to the NI 9208. Would be great if someone could provide me some wiring plan.
Many Thanks to you all,
Marco
04-24-2018 03:38 AM
Hi Marco,
I see that there is no activity around this question. Did you manage to solve this problem? Just by reading through your question I am a little bit confused about 9208 statement, was it supposed to be 9207?
