Multifunction DAQ
accuracy of analog input timing?
We're taking some analog data synchronized with a high-speed camera; I think we'll be using our workhorse 6023e. We have a start pulse (triggering) and a TTL sync pulse (timing) from the camera, and it should be straightforward. One thing - our customer is concerned about the timing accuracy.
Is there a spec or estimate somewhere for the typical time lag between the TTL trigger coming in, and the analog sample being acquired? This would be at around 5kHz. I checked the spec sheets and found timebase accuracy but not the accuracy with an external TTL trigger.
Thanks in advance for any help anyone can provide!
(2,697 Views)
If you are using an external signal, the time from the first trigger to the first conversion will be 338ns + (One period of the pulse train). This is the worst case scenario. This is true only for the the DAQ STC chip for E-Series devices.
Raajit Lall | Applications Engineer | National Instruments
Raajit L
(2,679 Views)
