11-18-2011 01:06 PM
Hi Roberto-
I consulted both the NI-DAQmx Help and the NI-DAQmx C Reference Help documents in order to confirm the information in my posts. You can find these from your Windows start menu under Start>>Programs>>National Instruments>>NI-DAQ>>Text-Based Code Support. You can find links to code examples for various text-based programming environments there, as well.
11-18-2011 01:24 PM
Thank you again Tom, I searched through those files too, but my search wasn't quite good as yours 🙂
11-18-2011 01:26 PM
Hey Roberto-
No problem- it definitely takes some experience to build your familiarity with DAQmx. I would suggest that you peruse the various shipping examples and observe the behavior, then use those documents to tailor it to your specific application.
Good luck.
