08-30-2024 05:51 PM
I am a little confused on what exactly TSN provides for cDAQ-9185/9189 chassis.
One thing we are looking to do is sample an analog channel in a NI-9209 module in a cDAQ-9189 chassis when the digital input of a NI-9401 goes low to high in a cDAQ-9185 chassis.
Does TSN provide signaling like this via ethernet/TSN or must physical lines be connected between two chassis for this particular example?
08-31-2024 03:58 AM
Short answer, no. Physical lines are not required between chassis. Time start trigger is used. Synchronization is done via TSN (IEEE 802.11as).
Long answer, see How to Achieve High-Accuracy Measurements With NI-DAQmx-Based TSN Devices
09-19-2024 11:42 AM
One other consideration, you would need to use a LabVIEW Linux RT controller for your system. TSN is not supported on Windows.
