Multifunction DAQ
can't create an installer in LV2009
I can compile an application but not an installer.  my installer includes an exe file and additional installer.  I can create the installer if I don't include either NI-DAQmx Application Development Support 9.5.5 or NI-DAQmx MAX configuration Support 9.5.5.  If I include NI-DAQmx Core Runtime 9.5.5 it will create the installer.  However, when I install it on my laptop I cannot see my DAQ configuration in Measurements & Automation.  I have an USB 6509 DIO.  I created 3 channels to support my project using the DIO.  I include this in the hardware configuration. I include the NI USB-6509 in Devices and Interfaces.  I also include USB-6509 Port 1 Out, USB-6509 Port 1 Out and USB-6509 Port 8 Out.  Then I export and that is included with my installer.
If I build with NI-DAQmx Core Runtime 9.5.5, it completes.  I install it on my laptop.  I plug in the USB-6509 DIO and it is recognized and the driver installs. But, the program cannot see the Ports I included.  I cannot see them or create any new ports in Measurements & Automation on my laptop.  I quess I need to include ni-DAQmx MAX configuration Support 9.5.5 and remove the Core Runtime since it is included with my new selection.  I build and receive this error.
CDK_CreateNewWizard_Invoke.vi.ProxyCaller >>
CDK_CreateNewWizard_Invoke.vi >>
CDK_InstallerConfiguration_Editor.vi >>
CDK_Build_Invoke.vi >>
CDK_Engine_Main.vi >>
CDK_Engine_Build.vi >>
NI_MDF.lvlib:MDFDistCopyList_CopyItem.vi
Loading product deployment information
Adding files to installer
Validating...
Copying files...
Scanning files...
Updating files...
Build complete successfully.
Done adding files
Preparing to build deployment
Copying products from distributions
Error: Input data from a source data file has errors.
(Error code -33)
Error Details:
Error in MDF API function: _MDFDistCopyList_CopyItem Error in MDF::DistributionSourceCollection::LoadDist Could not extrapolate product location on distribution because paths do not match Path of part on distribution: Products\DotNet20langpack_x86_Installer\DotNet20x86langpack.msi Path of part in product: DotNet20x86langpack\DotNet20x86langpack.msi
*** End Error Report
Done building deployment
Should I download the NI-DAQmn 9.5.5 full package and reinstall it on my development computer?  Would this solve this error?  Should I install NI-DAQmx 9.6 instead.  I'm running LabView 2009 Pro 3rd quarter.
Thank you in advance for your help in this matter.
Ron
(2,681 Views)
Ron,
I would say do try as you asked. Try both and see if that makes a difference. Also, here is a white paper which I'm sure you are familiar with but it does not hurt to include on here just to make sure you are not missing a step in the deployment of your application.
http://www.ni.com/white-paper/5406/en
Please give us updates and any other information which you may feel is pertinent to this issue.
Daniel G.
http://www.ni.com/support
Daniel G.
Semiconductor & Wireless
(2,653 Views)
