05-25-2009 11:07 AM
I'm having trouble building an installer for my application including DAQmx 8.9. I've included an EXE, LV Runtime (8.6), MAX 4.6 and NI-DAQmx 8.9. If I don't include DAQmx 8.9 it builds fine, but the EXE does not find required files (one particular DLL especially). When I do include DAQmx 8.9 the installer never finishes building. I've had other installers take a long time to build, so I let this one continue building for up to 24 hrs with no success. I've tried on a couple of different PCs (Vista AND XP) with the same results. I've tried different levels of DAQmx (Full, Runtime, Runtime5 etc.) with the same results. I did not have this problem with the previous version of DAQmx (albeit the build did take a LONG time). I tried uninstalling and reinstalling DAQmx 8.9 and no success. I tried repairing DAQmx 8.9 and no success. Anyone else having this problem?
05-26-2009 10:26 AM
Hey,
I should try to not include MAX in the install, as it is installed by the DAQmx Driver and you could be having a conflict occur. You may also want to double check that your exe is working on your build machine. You could also try taking your exe over to another machine with same version of LabVIEW and DAQmx and try to build an installer from there. I tried to reproduce this on my machine with LabVIEW 8.6.1, DAQmx 8.9 and was unsuccessful.
Doug
05-26-2009 05:15 PM
05-27-2009 02:07 PM
