01-23-2014 06:07 AM
I am using the C API of Daqmx Base with a 6212 USB.
I can successfully create analog input task with a digital start ref trigger.
I can successfully create a counter output or a analog output.
Once the task is created I loop to do the following:
Start AI task – read AI data – Stop AI task
By doing so I can kind of reproduce the Digital Edge Reference Trigger, except that I do not have pre-trigger samples.
Anyway this works great. The problem arises when I create a counter task (or even an analog OUTPUT task). If I create another task the (Start AI task – read AI data – Stop AI task) loop will work at the first occurrence, but at the second I have a nasty error on the start task.
Does anyone encounter this kind of error? Were you able to solve it?
01-28-2014 03:51 AM
Hi Novatrex,
Can you elaborate on the details of the error, do you have a specific error code and mesage? If so, you could you paste them here or give a screenshot showing the error. Also it may be beneficial if you were able to attach a copy of your code so that I can take a look at it.
Best Regards,
James Kent
