Multifunction DAQ
momentary push button to anlalog input
We have a USB 6210 DAQ, I want to connect momentary push button to anlalog input to find when the button is pushed. Can somebody help with electrical connections that is needed.
Thank you
(3,258 Views)
Connect a pullup resistor to +5V, connect the other end to the switch, connect the other end of the switch to gnd. Connect your analog (or digital) input to the switch/resistor connection. The DAQ input will see either gnd or +5V.
(3,254 Views)
Thank you Dennis,
What is value of resistor,  I would appreciate if you can how calculate, I know voltage is 5 v, and what is the current value to be used in equation (v/i=r)
(3,251 Views)
First check the manual to see if the digital lines aleady have pullups. If not, read the manual for max current in. A 10k will probably work fine.
(3,247 Views)
