01-29-2019 11:38 AM
Trying to diagnose a lack of output on a NI 9265 20mA analog output board. To do this, I've got...
- 24VDC to Vsup & COM
- DMM closing the loop AIx & COMx
- Running Test Panel to adjust the output of a particular channel
When I change the output level on the Test Panel, I see a jump in mA, but it then returns to zero. I'm expecting the mA output to stay constant and the prescribed level. Isn't that how its supposed to work?
I see the same behavior when I run a simple AO VI to test the 9265 output. That is, when I change the FP control input to the DAQmx write data, I see a jump in the DMM mA reading, then return to zero. Not what I'm looking for.
Thanks for any input on this,
Greg
Solved! Go to Solution.
01-29-2019 12:40 PM
Any chance your DMM is set AC mA and not DC mA?
-AK2DM
01-29-2019 01:52 PM
Good question. I'm not that familiar with the DMM, but it did have a units reading mAAC. That would explain it. I'll check.
Greg
01-29-2019 04:25 PM
Yes, that was indeed the issue. When I switch to mADC mode, I get the output that I specify.
I did observe however that when I stop my DAQ task, the mA output stays on, even though I have a DAQmx Stop Task.vi after exiting the DAQ loop. For my application, I want to return to 0mA or 4mA on exit.
Thanks for your help!
Greg
01-30-2019 07:59 AM
Greg:
Add another set value function to 0 or 4ma outside the loop before the Stop Task.vi.
You're welcome!
-AK2DM
01-30-2019 11:24 AM
Right, I thought of that too, and that works. But the DAQmx Stop Task function is to "return the state before the Start Task". That's not happening.
Greg
