Multifunction DAQ
no supported devices found
Hello. I am trying to use my NI 6221 PC Card in in the DAQ Assistant and am having issues. When I open up the MAX the deviced is there (in the DAQmx section) and appears to be working properly (self test, test panels,...), however, when I open the DAQ assistant Express VI that I have placed in my block diagram and try to add a voltage channel to the channels list, I am left with a message saying there is no supported device found under the physical channels list. has anyone had this problem before? does anyone have any suggestions?
Chris
(2,825 Views)
Hi Chris,
Thanks for the post.
This KB is useful:
basically check,
1) is device found by MAX - yes
2) Does it show up in windows device manager?
3) Ensure device is installed on the system?
Maybe use MAX to simulate the device, and see if the DAQ assistant works - this would then suggest the problem isnt with the DAQ assistant.
Let me know how you get on,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,819 Views)
Found!!!!
The problem was coming from vista !!!!!!!!!!!!!   By default, LabView is not install to run in administrator mode !!!!! After checking the appropriate chek box in LabView.exe properties it was working fine !!!!!!!!!!!!!
(2,815 Views)
