10-11-2010 11:12 AM
Greetings:
I realize that the PCI-1200 is no longer supported. Our software is being rewritten to use a PCI-6220 instead, but rollout is quite a ways away. With XP not being supplied any longer, customers are needing to update their systems, but I seem to be in a no-win situation.
Is there any solution to using a PCI-1200 in Windows 7?
From what I can tell, Legacy NI-DAQ is all that supports the PCI-1200, but it is not compatible with Windows 7. For Windows 7, I need to use NI-DAQmx, which doesn't support PCI-1200. I've been checking into running XP mode in Windows 7 (a virtual PC), but then only certain processors are compatible, and even Microsoft describes limitations to XP mode, so at best it seems a gamble if the NI-DAQ driver, board, and our software will run in that context.
Do I have any options to the software re-write other than the XP mode (Windows 7) gamble?
Leland
10-11-2010 09:11 PM
Upgrading to a card supported by DAQmx in the long run would save you alot of time.Theres a trial driver that allows legacy devices to run on windows 7, its discussed here on in a similar post
-Ciao
10-12-2010 11:34 AM
Hi LelandDurrette-
You can try the TraditionalDAQ 7.5 bets as recommended above, but other than that, there are no other options beside the Windows 7 XP 'gamble'. The TraditionalDAQ 7.5 beta driver is not guaranteed to work on Windows 7, but has worked in some cases.
Best of luck with your application and have a great day!
10-12-2010 12:28 PM
Disregard my first post: I looked through documentation for the Traditional DAQ beta and found that it does not support the PCI-1200. TDAQ stopped supporting the 1200 in TDAQ 7.x.
If you choose to go with the Windows XP option, you can download NI-DAQ 6.9.3.
Have a great day!
10-12-2010 07:21 PM
Hi Leland,
Windows XP Mode cannot access PCI devices directly, so you cannot use it to make your PCI-1200 work with Windows 7.
On the plus side, Microsoft has supposedly extended Windows XP downgrade rights to cover the entire life cycle of Windows 7.
Brad
10-13-2010 09:48 AM
Thanks, guys, for the information. I had already seen where the DAQ 7.x didn't support PCI-1200, but appreciate it. Took some digging to uncover it.
As far as the downgrade being extended, that, I believe, is my solution. I hadn't heard that, and most-likely wouldn't have run across it on my own.
Thanks again,
Leland
