Multifunction DAQ
strain gauge with ni usb 4431
would you please tell me can I read strain gauge with NI USB 4431?
Regardsa
(3,098 Views)
Yes you can do it. The problem is that it will take you a lot of work to do it.
Since it is not a device we design to take in this type of measurements, you will have to do all manually. NI's software does not support strain measurements for this USB device, so as scaling and excitation will have to be done manually by you.
Also you will require a BNC adapter to connect the strain gauge. You will have to build the bridge depending if it is a full bridge strain gage, half or quarter.  With the output channel you can provide the excitation to the Strain Gauge.
We recommend getting a Bridge/Strain Measurement Device for this type of measurements since it will be much simplier for you. An alternative for USB measurements is the NI 9237 Module: http://sine.ni.com/nips/cds/view/p/lang/en/nid/209891.
Alejandro Vargas
(3,055 Views)
Thanks for your good comment.
already I have a USB 4431.
would you plaese tell me more detail about strain measuerment with this DAQ?
regards
(3,052 Views)
