Multifunction DAQ
synchronization for AI, AO and DO signals on 6014.
I want to realize the synchronization of the AI, AO and DO signals on 6014. Here is an Error 200077 for th sample clock of the DO route  when I use a CO signal as the soure.
How can i solve the error?
(3,527 Views)
Accepted by topic author swinhaibo
Hi swinhaibo,
the DIO lines in PCI-6014 are software-timed, so you cannot connect any clock signal to control them. That is why you are getting an error. Unfortunately there is no way around it other than using different hardware.
(3,525 Views)
Thank you for the anwser.
(3,486 Views)
