Multifunction DAQ
what is maximum read out speed of USB DAQ 6343
hello everyone,
we have new USB DAQ 6343.Its application note(or say characteristcs) says that it's sampling rate is 500K Sample/second.Now i need some clarification from you guys.I have to read digital data(serial or parallel). so plz tell me how much far I can go with this product for both ways.
thanks in advance,
(4,118 Views)
Unfortunatly I can't get the spec online
Error
You are not authorized to view this document
but you should have get it with your device 😉
However the datasheet is telling me something like 500kS/s aggregate (500kS/s / <number of channels read> ),  but up to 1MS/s for digital input. However you need to get the data into your PC. If you read one 8 bit port @1MS/s the USB should be able to handle the datastream.
Greetings from Germany
Henrik
LV since v3.1
(4,112 Views)
Accepted by topic author d_2014
While not for the 6343 here is a post that maybe can help about the X - Series cards
http://forums.ni.com/t5/Multifunction-DAQ/USB-6351-digital-streaming-output-rate/m-p/1506848/highlig...
Henrik
LV since v3.1
(4,107 Views)
thanks a lot
(4,086 Views)
