3. Schematic: To add active probe (see CircuitMaker 2000 solution).
With the 14 version release there are probes feature added that I did not have a chance to evalute however probe can be moved dynamically to the specific net to check a signal level (voltage or current) or when you place on a component so power dissipation can be measured and showed (power dissipation vs time).
Notes:
This idea is splitted from topic "NI Multisim - new ideas" posted in 2014:
http://forums.ni.com/t5/Multisim-and-Ultiboard-Ide
If some ideas are implemented in NI Circuit Design Suite 14 they shall be skipped and topic can be removed by admin.
