07-15-2010 04:46 AM
I am trying to save the output of a circuit to a file. I am using hte oscilloscope's save feature. The problem is that it resets it's internal buffer after a while so I only get about 0.5 seconds of data.
I am trying to determine the audio output of a circuit. I use a piecewise linear input of a converted wave file(from matlab) and then use the scopes save feature then convert it back to wav in matlab. This is a very annoying sequence to go through just to get some output.
NI needs to add a wave in and wave out instrument(how hard could it be?) Or even an instrument that can read multiple types of files and will input them or save them(capture and save to wav, txt, or whatever).
07-16-2010 10:06 AM
You can export the scope data to an Excell file and to do this select View>>Grapher>>Tools>>Export to Excell.
07-17-2010 03:57 AM
The problem is that the scope data resets aftera about 1/2 a second of simulation. Hence if I let the simulator run to capture all the data and try to save it I'll only get at most the last 1/2 second.
07-19-2010 03:38 PM
Select Options>>Global Preferences>>Save, increase the memory size in the "maximum size" field.
07-20-2010 12:47 PM - edited 07-20-2010 12:56 PM
This has no effect on the scope buffer. I set it to 300M and 1M and they both get "reset" at 0.6s. The memory used was 30M and did not increase after it was reset.
The scope resets by restarting from the far left as if you just started up the sim. It does it always at 0.63s regardless of the time scale(so even if it's just using 1/10 of the scope's window it will reset). Saving the file after a reset doesn't retain the previous data.
A memory buffer option needs to be added for the scope(as it should be independent of the "save buffer"). I'm guessing it is hard coded to 30M.
The transient analysis simulation does not have the problem.
07-21-2010 08:12 AM
I apologize but there is one setting I forgot about, select Simulate>>Interactive Simulation Settings>>Analysis Options select the "Continue without discard previous plots".
07-21-2010 04:31 PM
Nope, didn't change anything...
03-24-2011 01:44 PM
Same trouble here.
I can playback only what's in the scope screen, regardless of the settings mentioned prior in this thread.
03-24-2011 02:19 PM
My Bad.
If I let the scope just run, it will play whatever length I let it run for.
