Multisim and Ultiboard
Frequency Dependent Impedance Model
Hello Everyone,
I need a frequency dependent impedance model. I have attachment data.
How should ı do ?
Thank you for your time and attention.
Prof. Anil
(4,268 Views)
Hello Anil.
Sorry but I'm not very familiarized with what you are asking, could you please give me an example of what you are trying to archive?
(4,182 Views)
Hi Prof. Anil,
You can use the FREQUENCY_TABLE_FUNCTION component from Sources/CONTROL_FUNCTION_BLOCKS family.
It allows you to create a Vout/Vinput transfer function by specifying discrete data points. You can simply paste your data points into the textbox, exactly as you have them, and select "Absolute" for the Magnitude units.
If your transfer function describes an impedance, you need to sample current and convert it to a voltage, which you can use as the input to the FREQUENCY_TABLE_FUNCTION component. That way you get current input, voltage output.
I've created a little sample using your datapoints to get you going.
Attached. Run AC analysis. The plot is the impedance since I am injecting a 1A phasor.
Let me know if this is what you're looking for.
Max
(4,165 Views)
Actually ı want use voltage source with my impedance model. Therefore ı changed circuit in attachment. There is a problem but ı cant find.
Regards
prof.Anil
(4,102 Views)
