Multisim and Ultiboard
Need pin names of a component of multisim database
Hi all,
I was trying to match a relay component :  "CONTROL_1C", in multisim database(because this is the only relay part that have 6 pins) with the relay part I have MPN: SY-5-K , Manufacturer: Fujitsu. I was able to modify the pin numbers of databsae part as per the datasheet. One thing that bothers me is which pin stands for what in the component that i took from Multisim master database as there are no other . I've took a chance and tried to get simulated. I have got the output but I want to be accurate about the pin names of the component of master databse.
                                             So please help me to get the pin names of the "CONTROL_1C" part, so that I can carry out the further simulation process.
Is that mandatory to add footprint to the component of the database for simulation to happened??
                                                            or else
suggeset me a relay component from master databse which matches the part that I have:SY-5-K. Please give me a solution ASAP.
 NOTE: relay symbol of datasheet in attached pic is shown in Bottom view
SASI
Message 1 of 1
(3,036 Views)
