03-31-2011 08:41 AM
i try to semulate this oscillator circuit,but it does not show any output oscillation from the oscilloscope!!!
can someone advice?..Thanks.
03-31-2011 02:18 PM
1. Resistor R5 should be more 10К (more, than resistor R2).
2. You have forgotten to connect an output of the amplifier to resistor R5 and capacitor C1.
04-01-2011 06:47 AM
i hv this circuit for wien bridge oscillator. i want to calculate the gain at different values based on changes in input and output voltage.
how can i make the change in both input/output voltage?
how can i show the oscillation waves of the gain and frequency,phase and frequency?
04-01-2011 07:14 AM
this circuit for wien bridge oscillator with output control,but it is not working!!! may someone help me?
04-01-2011 11:40 AM
If you put the variable resistor it is necessary to use all 3 pins. Also choose other opamplifier.
04-01-2011 07:17 PM
thanks alot for your help.i appreciate it.
04-01-2011 07:30 PM
i hv another ciecuit for wien bridge passive oscillator and i want to compare the voltage input/output.
what power supply should i use? and how can i see the wave form? in both sides?
04-01-2011 08:46 PM
For comparison of signals on an input and an output you can use Bode Plotter.
04-01-2011 09:41 PM
i connect the Bode Plotter but still it cannot run!!
do i need to connect power supply? how?
04-01-2011 09:47 PM
i am trying to get different values of input/output voltages to compare the change in Gain/phase with respect of frequency changes.
is this circuit correct?
