Multisim and Ultiboard
using prescaler in Multisim10
Hello, I would like to ask you if I can using prescalers in Mulisim10, I have prescaler U664 or there is possibility to download the model and add it? thank you
(4,542 Views)
Hello yalect,
If you have the SPICE model you can always create a new component using this documents as guide:
http://www.ni.com/tutorial/3173/en/
In this document a list of all components of Multisim depending of the version:
http://www.ni.com/white-paper/5607/en/
If the component is not present in Multisim database version you will need to create it.
Randy @Rscd27@
(4,503 Views)
Hello, really, I didn't find my component Prescaler U664 but may you can help me to creat one basing on the Datasheet Thank you
(4,498 Views)
Hello Yalect,
I believe the tutorial is pretty straight foward and easy to follow. If you have any question about a part of it I will try to answer your questions, but you will have to create the component yourself. You will need the SPICE code and that is usually obtained from the component manufacturer
Randy @Rscd27@
(4,493 Views)
