NI製品ディスカッション
キャンセル
次の結果を表示
次の代わりに検索
もしかして:
How to pick up selected data
Dear Lab VIEW Engineer
I am Lab VIEW user.
I have two questions to manipulate some data.
1. I have x-y data. I want to pick up minimum coordinate from that data?.
2. How to export data from labVIEW to excel or text file?
Thank you
Best regards
Sugeng
0 件の賞賛
メッセージ1/3
3,422件の閲覧回数
Dear sugeng,
Thank you for using NI product.
I am Emi, an application engineer from National Instruments.
1. I assume the minimum coordinate as the smallest y?
if the x-y data are array, you can use
Array Max & Min
function in Array.
2.
[excel] in File I/O, there is Write to Spread Sheet file.vi
 you can simply insert data in this function to save your data.
[text] in the same pallet there is Write to Text File function
for this one, you first need to place
Open/Create/Replace File,
wire the refnum to Write to Text File
then wire refnum from Write to Text File to Close File
for both function, there are good examples.
Place the function, place mouse over the fuction,
then try [Ctrl + H].
help will show up, and then click online help.
at the bottom of the help there are examples,
which are probably more helpful then my explanation!
But let me know if you have any more question regarding this.
If you have a completely new question,
if will be nice if you can create a new topic.
Thank you!
Emi Nakayama
NIJ Application Engineer
Emi Nakayama
Applications Engineer, Japan
0 件の賞賛
メッセージ2/3
3,410件の閲覧回数
E.Nakayama さんは書きました:
Dear sugeng,
Array Max & Min
function in Array.
2.
Thank you!
Emi Nakayama
Dear sugeng,
Array Max & Min
function in Array.
2.
Thank you!
Emi Nakayama
Thank you for your help
I can found the VI that you mean, but I am still cannot use the VI.
Could you give some simple  example?
Thank you
Sugeng
0 件の賞賛
メッセージ3/3
3,391件の閲覧回数
