When using the oscilloscope in Measurements Live, I want to reduce the sample rate, to reduce the size of data files we save using the export function. I thought the decimate function would do this. However when I select "decimate" under acquisition I see "decimate, off" and no way to turn it on, or to select by how much we reduce the sample rate.
The manual says we ought to be able to reduce the sample rate by a factor "N" and I would expect to be able to set that factor, and to see "decimate, on".
Does anybody recognise this issue please?
