09-24-2020 11:12 AM - edited 09-24-2020 11:18 AM
When I try to connect the Elvis III in Measurements Live, it fails to connect and I am unable to use the SFP's.
I have a new Elvis III that is visible in MAX under "Devices and Interfaces". It is not visible under "Remote Systems". When powered on, my PC alerts me of the USB connection. The the USB connection shows up in my device manager. The Elvis is only identified as "USB Composite Device", "Portable Devices", and "Generic USB-EEM Network Adaptor". The network adaptor device has the warning triangle on it.
The Elvis reflects a USB IP address but also states "ID: Not available."
All set-up steps were followed IAW the provided documents and the NI YouTube channel. The Elvis Software Bundle was installed prior to connecting the Elvis to the laptop. I have un/re installed several times. The Elvis is registered under my NI account.
I am using Google Chrome to launch Measurements Live.
Any help is greatly appreciated.
09-24-2020 11:15 AM - edited 09-24-2020 11:18 AM
The Elvis III is also identified as as Elvis III under "Portable Devices" in my Windows 10 Device Manager.
03-12-2021 11:21 AM
We're having the same issue, any assistance would be greatly appreciated.
03-15-2021 06:47 AM
add the Elvis url to your java security settings, fixed it for us
03-15-2021 09:04 AM
could you please explain how?
03-30-2021 05:50 AM
Yes, I have now the same problem. I can see Elvis in NI MAX under devices and also under Remote Systems (it si connected and running) but in MeasurementLive it is not possible to connect via USB. And for Wi-Fi I cannot set up the ID. Can you mentioned your solution, please?
07-14-2021 12:29 AM
I am also facing the same issues. Please reply me if anyone knows.
07-14-2021 03:09 AM - edited 07-14-2021 03:11 AM
I found the simple solution, try it. The problem on my laptop was with the new version of Google Chrome which stop the support of live connection so I installed SlimJet Browser (https://www.slimjet.com/) and the Elvis and MeasurementLive work perfectly in it.
Hope it helps you also.
03-09-2022 02:07 AM
Me too. I'm also facing the same issue. Anyone! could you help me. Please!!!
03-09-2022 03:01 AM - edited 03-09-2022 03:02 AM
So I solved it so, that I use browser SlimJet in version 30.0.5.0 and I fixed this version (disallow updates). It works 🙂
