NI ELVIS
NI ELVIS III Impedance Analyzer
I am an engineering student.  We were advised that we could use the NI ELVIS II or NI ELVIS III, I have an NI ELVIS III, but all the instructions are written for an NI ELVIS II.  My question is: is there a way to run an impedance analysis like you would see in the ELVISmx Impedance Analyzer for the NI ELVIS II via the IV analyzer (Current-Voltage analyzer) or other tool.  I have searched through the manual and I was unable to find information regarding my question.  Any direction on this would be greatly appreciated.
This is the NI ELVIS II Impedance Analyzer tool for reference.
(2,988 Views)
To measure impedance on NI ELVIS III, you can use the built-in function generator and the oscilloscope features of the NI ELVIS III software. Here's a step-by-step guide:
  1. Connect the device or component whose impedance you want to measure to the NI ELVIS III.
    • For example, if you want to measure the impedance of a resistor, connect it to the appropriate terminal on the NI ELVIS III.
  2. Launch the NI ELVIS III software on your computer.
  3. Configure the function generator:
    • In the software, go to the "Instrument Launcher" tab.
    • Select the "Function Generator" instrument.
    • Set the function generator to generate a known AC signal, such as a sine wave, at a specific frequency.
    • Adjust the output amplitude and frequency settings as desired.
  4. Connect the function generator output to the device under test (DUT):
    • Use a BNC cable to connect the function generator output (usually labeled "FG") on the NI ELVIS III to the input of the DUT.
  5. Configure the oscilloscope:
    • Select the "Oscilloscope" instrument.
    • Set up the oscilloscope to measure the voltage across the DUT.
      • Connect the DUT output to one of the oscilloscope channels using a BNC cable.
      • Adjust the voltage range and timebase settings on the oscilloscope as needed.
  6. Capture the voltage waveform:
    • Start the function generator output to generate the AC signal.
    • Capture the voltage waveform across the DUT using the oscilloscope.
    • Make sure the waveform is stable and representative of the AC signal being applied.
  7. Analyze the waveform:
    • Measure the peak-to-peak voltage of the waveform using the oscilloscope's measurement features.
    • Note down the frequency of the AC signal generated by the function generator.
  8. Calculate the impedance:
    • The impedance of the DUT can be calculated using Ohm's Law and the measured voltage and current values.
    • Impedance (Z) = Voltage (V) / Current (I)
Note: The specific steps may vary depending on the software version or updates provided by National Instruments. It's always a good idea to consult the documentation or user manual for the NI ELVIS III and the software for detailed instructions
(1,726 Views)
