NI FlexRIO Network
read to 128 pin with FIFO DRAM
I have a problem.I read from a 128 pin connector through the FIFO DRAM.
Signal must be read with a clock of 64 Mhz  because signals are square waves with a maximum frequency of 16 Mhz.
Finally, i have to host a single plot waweform accessed from a single pin .
Can anyone give me some help for the right onfiguration of the FIFO DRAM read e write ?
My Flexrio are 512 has 2 Banks of 512 MB of Ram.
Thanks.
(4,781 Views)
Hello!
I would suggest creating a service request at ni.com/support and one of the Applications Engineers will be able to help address you questions. When you work with support, the following additional information will help them aid you much quicker.
  • Which FlexRIO are you using?
  • Which Adapter Module are you using?
  • What are you trying to accomplish with your hardware?
  • Have you tried using one of the shipping examples for your adapter module that can be found in the Example Finder within LabVIEW? There are Three Examples for using DRAM and the FlexRIO.
Thanks!
Ben Sisney
FlexRIO V&V Engineer
(3,815 Views)
