NI Labs Discussions
EthernetIP & CompactLogix 2 Dimension Array
First I would like to thank you for all your work on this project. Great job!
Can someone help me on the proper Tag syntax for a 2 dimenional array using EthernetIP Tag Read VI . In CompactLogix it is System[0,0] through System[0,6] at the moment.
Using a tag of System[0,0]  to select a single element of the array returns an error.
thanks,
Glen
(5,019 Views)
Do you have any example code that could help get me started?
Eric
(3,081 Views)
It's been a long time since I came across this problem. It may take me a day or so to dig up the code.
Glen
(3,081 Views)
Sorry it took me so long. I looked at my old projects and I don't think I ever found a solution for reading a 2D array of values. Maybe someone else has the answer.
Glen
(3,081 Views)
Thank you for taking the time to look into this for me. Do you have any examples of reading arrays from a Logix Controller using EthernetIP?
Eric
(3,081 Views)
