04-06-2011 01:34 PM
Well the problem is that after you do the System Configuration 5.0 Install then your ability do use MAX to do a software install on a formated cRIO is totally hosed up and requires either LVRT2011 or some delicate subinstallation surgery that I could not fathom. Can't we just have a new syscfg.lvlib to fix the problem?
04-06-2011 01:50 PM
The lvlib is just a simple wrapper that calls in to a collection of DLL's that do all of the actual work. So, a new syscfg.lvlib wouldn't fix the issue and you can't just copy DLL's around since their dependencies would most likly not be met.
04-15-2011 11:49 AM
I am trying to deploy a cRIO image using the API and am getting the following console out error after deployment and reboot.
If I use the RTAD utility everything work fine. In the boot sequence it appears that the line:
* Loading nidp_target_end.out: nidp_target_end
appears out of sequence to where it is located on the 'good' RTAD deployment reboot. I am wondering if the startup script? has become lost or mangled.
Loading LVRT...
* Loading nirtdm.out: nirtdm
* Loading nimdnsResponder.out: nimdnsResponder
* Loading vxfpsup.out: vxfpsup
* Loading tsengine.out: tsengine
Time sync source: ptp now active
* Loading nisvcloc.out: nisvcloc
* Loading RTWebServer.out: RTWebServer
System Web Server started
* Loading mxssvr.out: mxssvr
* Loading /tmp/webservices/NI/nisysapi/nisysapisvc.out: nisysapisvc
* Loading nisysapirpc.out: nisysapirpc
* Loading NiViSrvr.out: NiViSrvr
* Loading NiRioRpc.out: NiRioRpc
* Loading nivissvc.out: nivissvc
* Loading nivision.out: nivision
NI-RIO Server 3.6 started successfully.
* Loading niserial.out: niserial
* Loading taggerrt.out: taggerrt
NI-VISA Server 5.0 started successfully.
NI-Industrial Communications for EtherCAT 2.0 started successfully.
Assertion failed: px != 0, file d:/P4/Perforce/ThirdPartyExports/boost/export/1.
3/1.3.5f1/includes/boost/shared_ptr.hpp, line 375
04-15-2011 04:07 PM
It appears that the System Configuration API is bent on damaging certain XML files when creating an image from a cRIO target. For example the ECATMaster__0.xml and ECATSlave__0__0.xml files are present but most or all of the content is not there. So I am curious...Is this another one of those 'known' issues that only NI knows about?
04-15-2011 04:47 PM
Hi sachsm,
Can you send us the image you're trying to deploy to your cRIO that's giving you errors with System Configuration API? You can upload it to our FTP here:
Post here with the name of the file and we'll see if we can reproduce the issue. Thanks!
04-18-2011 04:48 AM
Can anybody tell me where I find the changelog of Ni System Configuration 1.2?
What are the improvements of this relase?
04-18-2011 09:55 AM
Ok, I have uploaded the file:
cRIO-SVU 1_0_0.lvappimg to the incoming directory.
You can use the standard RTAD utility to load this file to a cRIO (9074) + 9144 etherCAT. The problem I am seeing with the API occurs when I retrieve
the image from the cRIO. It appears to damage the previously mentioned xml files.
04-20-2011 10:51 AM
Any luck yet reproducing the image corruption problem?
04-21-2011 12:21 PM
sachsm,
Yep I've been able to reproduce the issue. We'll look into why this is happening.
DaBenny,
We post a Known Issues List and a Bug Fix List for System Configuration. I will provide links to these once they're available.
09-28-2011 10:31 AM
Links to Known Issues Lists and Bug Fix Lists:
MAX/SysCfg 5.0 Known Issues:
http://zone.ni.com/devzone/cda/tut/p/id/13303
MAX Bug Fixes:
http://digital.ni.com/public.nsf/allkb/4DA2BCEF4200FF1B862573A600741AF9?OpenDocument
SysCfg Bug Fixes:
http://digital.ni.com/public.nsf/allkb/98D42543957D9758862577DD005B6785?OpenDocument
