09-24-2014 02:25 PM
Description
Having trouble discovering your networked real-time target through Measurement & Automation Explorer (MAX)? Networked device discovery is a complicated procedure that can be affected by several variables including (but not limited to):
This wizard will intelligently guide you through a set of troubleshooting steps specifically designed for your target. Troubleshooting procedures are modified based on the properties of the target (ports, switches, OS, etc), information about your system configuration, and the types of troubleshooting tools you have access to (serial cable, USB cable, etc).
Feedback & Discussion
To help National Instruments better characterize and address challenges related to networked target discovery, please use the feedback submission form that appears when you exit the wizard to submit your troubleshooting session logs.
Please use this page to ask questions, start a discussion or post any feedback you have on the Real-Time Target Discovery Wizard.
09-30-2014 10:57 AM
Hey Nick,
You may want to add a link to the download page to your post. If someone finds this via search it will be difficult to get to the download page.
As for the wizard itself its looking good so far but I ran into a snag. When I loaded it up, windows asked me if I wanted to let the wizard through the firewall. But when I get to the firewall page, it says the wizard can't get through. I try hitting "add rules" and a windows admin dialog pops up and something runs, but at the end the firewall settings still show up as bad. Max does not have an issue. Any thoughts?
Daniel
09-30-2014 01:21 PM
Daniel,
I think I have an idea of what might be causing the problem. Can you do the following:
I think we attempt to remove rules blocking the wizard by the executable name and not by the application name. Therefore, if you have a rule blocking by application name (Real-Time Target Discovery Wizard) I don't think we find that currently.
09-30-2014 05:11 PM
Hey Nick,
It looks like TDT Wizard was unblocked, but the "Real-Time Target Discovery Wizard" was blocked for 'public' connections (I am on a 'private' connection of course). I set the system to allow these connections and it works now.
Daniel
10-14-2014 10:41 AM
Daniel,
The wizard download has been replaced with a version that contains a fix for the issue you reported as well as several other fixes.
-Nick-
