NI Linux Real-Time Discussions
Application Running Embedded Python on NI-RT Linux
I was wondering if anyone has built an RT application with LabWindows/CVI that has embedded Python into its runtime. I'm also looking for input into whether or not this is possible.
From what I can gather, you can install Python 3 on NI-RT:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DzbVCAS&l=en-US
With this in mind, I believe I should be able to build an RT target that uses Python C-API to instantiate a python runtime into my application.
I'd like to build a host application that sends a Python script to the RT application. The RT application executes the script, which does little more than manipulate some software signals inside the C runtime. The RT application then sends a file back to the host when python execution finishes.
Any input would be appreciated!
-Chris
Message 1 of 1
(167 Views)
